Old 06-03-2011, 20:13
silviagod's Avatar
The pink wire is the ground for the lights and it comes from the variable resistor on the illumination conrol knob. If the illuminuation control unit is faulty the lights won't work, if you put the pink wire to ground the lights should operate but you will then be bypassing the illumination control unit.
