Old 19-03-2006, 16:49
yeah, i'am wondering if timing the cam in will take it up the rev range, i'am a bit confused really cos piper told me that the std cam was 256/108 degrees, and the piper item was a 268/110 degrees, but i think martin said that std was 110 degrees and piper was 112 degrees, i ant got me manual here to check, can anyone check there manual if possible. i'll ring piper again 2mz for the spec of there's.
Old 19-03-2006, 16:54
Adjusting the cam will only make a small difference. The pipe cam is set to 110 degs and the standard one is 112 degs
Old 22-03-2006, 16:02
i suppose you have to try anything when your chasing those last few horses.
Old 23-03-2006, 12:29
FLEXXX's Avatar
FLEXXX FLEXXX is offline
mad figures and all that from an 8 valver nice job mate
Old 23-03-2006, 21:31
rob turbo's Avatar
take it thats flywheel power....
Old 23-03-2006, 21:34
i should think so yeah. Awesome results.
Old 25-03-2006, 08:28
yeah, according to wrc technologies at silverstone the place where i hade it dyno'd before use a marha set up and it reads 5% more which would have given me about 321bhp, i also had a RR read 9bhp more than the marha which would be about 330bhp, its good bhp for an 8 valve, but all rollers are different so its no use comparing unless the cars are on the RR on the same day.
