Old 03-08-2011, 18:31
Originally Posted by TooleyS15 View Post
Would you be able to knock some up for the mrs s12? or let me know the legnth of the coilover tubes so i can cut some to size?
i'll get you all the measurements matey, the coilovers are only in the room next to my kitchen.
Old 03-08-2011, 19:12
[pedant]they're not actually coilovers tho[/pedant]
*jogs on
Old 03-08-2011, 20:38
*jogs on
ajustable spring platforms, but if they are no good then i may as well not post any info up about them then.
Old 04-08-2011, 10:17
paulsilv's Avatar
paulsilv paulsilv is offline
Post the info Shaun, this is good stuff, I;ve seen them in the flesh and they are spot on
Old 04-08-2011, 10:25
Jost joshing there our Shaun
Old 04-08-2011, 10:55
the metal tube for the platform is 50mm high, by 4mm thick and about 90mm diameter, then just grind a circle for the top out of some 4mm plate, the threaded tube is from rally design's its about 100mm long and if you use a 9 inch spring, then you can get the stock hight of around 12 inch and you can adjust it down by about 2 1/2 inch.
Old 04-08-2011, 16:59
thanks mate for that i rung rally designs today its about £100 to do it + p/p
what weigth are the springs ?? i would like hard ride as its a track car and low !!!
so not standard heigh
Old 05-08-2011, 23:24
paulsilv's Avatar
SOLD
I'll have 2 please
