Old 17-09-2011, 07:47
Hi where about are you
have you tested the loom and checked your earths
dose it just turn over or try to start
Old 18-09-2011, 02:39
Have you tried to read the fault codes from the ecu?
Old 18-09-2011, 19:11
tim murphy's Avatar
can you check power to the coil if you have power from it work forward or back if not a good mate told me this every problem has a solution: . cheers
Old 20-09-2011, 13:08
tim murphy's Avatar
hi just wounder hows the car going . have you check the crankshaft senor out not working no spark. cheers.
Old 24-09-2011, 17:49
the dizzy loom must be faulty. the s12 dizzy has an internal cam angle sensor which picks up top dead sensor.Get your guys on it.look at the wiring diagrams on the pdf downloads
or firstly yourself, check the 12v feed to the DIZZY. manually add a supply from the battery. i bet the bastid starts.
