Old 26-09-2011, 18:44
Default Random turbo thoughts.
This is kind of a passing whim, but I'm tempted by the idea as an "I have to try it" thing...unless anyone can save me the effort by knowing better!
I was aware of the fact that you can combine bits and pieces of T25 and T28 turbo's for some interesting results. (Sort of "ghetto" hybrids).
Now I have a fubared T28 and a T2, what do you reckon the result would be of using the T2 exhaust housing, and the T28 inlet housing with respective blades?
I'm thinking it would lack puff at the top end, which is not a massive issue, but would it come on boost real hard and pull hard pretty far through the rev range?
Thus making for a really fun to drive car.
Old 28-09-2011, 11:37
i had a roller bearing t25 with a t28 exhaust housing on an s12 i had once.
It performed well along with a fmic and standard ecu/fuelling.
Old 28-09-2011, 22:47
Yeah...I had one when I was 18 with a t25/t28 hybrid on it, but no FMIC, and therefore not much boost. So I didn't ever really get to see the end result. I'm tempted to go with that option again, but maybe with a 360 degree thrust bearing this time, FMIC and probably some 444's etc. to see what it's like.
I've just never seen a t2/t28 hybrid, although there's probably a really good reason for it!
Old 29-09-2011, 07:41
what are you going to controll the 444's with matey ?
Old 29-09-2011, 12:31
at a guess i would think the reasoning would be that the t2 exhaust housing would restrict the output of the t28 intake. Gases expand with heat..........so having a matched or slightly larger exhaust housing has similar gains to say fitting a bigger bore exhaust system.
Old 29-09-2011, 12:33
s13 injectors will be sufficient for a t28
