Yeah...I had one when I was 18 with a t25/t28 hybrid on it, but no FMIC, and therefore not much boost. So I didn't ever really get to see the end result. I'm tempted to go with that option again, but maybe with a 360 degree thrust bearing this time, FMIC and probably some 444's etc. to see what it's like.
I've just never seen a t2/t28 hybrid, although there's probably a really good reason for it! |
what are you going to controll the 444's with matey ?
at a guess i would think the reasoning would be that the t2 exhaust housing would restrict the output of the t28 intake. Gases expand with heat..........so having a matched or slightly larger exhaust housing has similar gains to say fitting a bigger bore exhaust system.
s13 injectors will be sufficient for a t28
he'll still need summet to controll the 375's, i tried them in my s12 just before i had the omex fitted, it ran for about a mile then coked the plugs up.
Yeah I was thinking alongthe lines of what you're saying pukka, just thought I'd chuck it up here and see what other people thought.
Might well go with a 360 degree thrust bearing T25/T28 hybrid, as that was ace on the one I had about 4 years ago. Never got to see the full end result though. Management wise I'm spending a fair bit of time pikeying around the t'interweb for options at the moment, although the two choices that keep springing back to me (partially for the "bang for buck" factor) is either going to be Megasquirt, 'cos I've fancied doing one for ages, and never got round to it. Or possibly Nistune, but I've never seen Nisture on an S12, so there may well be a good reason for that! Any thoughts/experiences. I've played with a couple of different management systems and engines, but never got as far as doing my old S12, just ran at low boost, before I had to get rid of it
