Old 22-07-2013, 23:17
You sorted yours Tim or you replaced it?
Old 23-07-2013, 15:01
bump... anyone seen this problem or know of any common problems/solutions? Just need a little heads up before i dismantle it on saturday (my next day off )
Old 23-07-2013, 16:28
tim murphy's Avatar
no bigdave can try greaseing it the thread when putting back on cheers :
Old 26-08-2013, 08:09
sideways_s12 sideways_s12 is offline
sideways_s12 is an unknown quantity at this point
I don't know if you guys have this out there but if you use teflon tape on the threads that usually works. But I would just replace the puny t2 with something better.
Old 26-08-2013, 11:27
mine had a small leak around the turbo once, it turned out to be a fracture in the oil inlet pipe where the nut tightens in the top right where the pipe flares. I hope i explained that well enough.
