Old 27-05-2014, 16:59
dlongmu dlongmu is offline
dlongmu is an unknown quantity at this point
I'm opening up the ECU tonight to check the resistor.. wherever it may be hiding
I'm getting error 21 (ignition signal) and 22 (fuel pump). I get error 22 before I even start the car, I think it's because of the way the walbro is wired up. Not sure what the best checks are for error 21..
I fitted brand new Magnecor KV85, it run smooth as a peach until it got hot, then it started missing gently, but it was more of a constant gentle miss - which is good in my eyes, more obvious to sort I hope.
Now to top it off, I always figured missing below 3k was down to a dodgy o2 sensor - so I check mine.. well it's not likely to work very well given its been replaced with a blanking plug!
Old 29-05-2014, 15:22
try this
http://www.scimitarweb.co.uk/sgwrs/v...hp?f=4&t=20398
http://www.scimitarweb.co.uk/sgwrs/v...php?f=4&t=2013
Old 29-05-2014, 18:13
cheers bro, i checked the ecu yesterday, it looks good, no evidence of burning or bulging?
im going to replace the coil. however i cannot get new cam/crank angle sensor anywhere. nissan never sold it separate from the dizzy, n no longer sell the dizzy anyway. no second hand dizzys floating about either
Old 19-07-2014, 22:34
ballbag ballbag is offline
ballbag is an unknown quantity at this point
mine wont always fire tried 3 ecus 2 distributors plenty of fuel plenty of spark but not always pulse to the injectors
Old 18-08-2014, 22:45
what immobilizer is it?
i would temporary bypass it and see if that makes a difference. most after market ones are cut in line behind the key cylinder. If it is cut into both your starter wire and your ignition wire then it could well be a faulty immobilizer ecu
it would be my first port of call .
Old 21-08-2014, 06:43
lmrdave's Avatar
lmrdave lmrdave is offline
I'm with Pukka on this.
My Eunos had a period where it would just cut out at random times, I checked everything, it sent me mad. By chance I found I could make it cut out with having the steering wheel at a certain angle, it was a loose earth on the immobiliser and it looped down near the steering column, when a joint on the column hit it, it would move it just enough to cut it out!
Nipped up the earth and it was sorted.
Old 22-08-2014, 08:27
My mark 1 did the same, warm up then cut out while driving. It was the optical sensor in the distributor, cleaned and replaced that then it was all good. Have a look on US s12 forum I posted some pics of my dizzy on there to give you a better idea
