Old 27-02-2016, 11:51
Robccsilvia Robccsilvia is offline
Robccsilvia is an unknown quantity at this point
Default Ca18et ecu problems
Does anyone know are any of the LEDS meant to be on
As standard? Or only in check mode. My car won't start and I can't
Get the ecu to go on dig mode. Or get any of the LEDS to come on
Old 27-02-2016, 20:30
tim murphy's Avatar
Hi are you getting fuel and a spark my ecu box checks on electric parts eg switches on engine will check my manual tomorrow cheers tim
Old 27-02-2016, 23:32
No spark no fuel no relays clicking anywhere
I've checked
And replaced
Coil/leads/plugs/tested all relays by putting power to them .
Getting nothing it will only turn over but not start
Old 29-02-2016, 18:45
tim murphy's Avatar
Hi have you checked the fuses in the car and the right rated to the fuel pump cheers tim
Old 29-02-2016, 18:48
Ecu is not working tho so won't turn fuel pump on.
Only fuses I have are under the dash and there all ok
Old 01-03-2016, 19:12
tim murphy's Avatar
Hi have you got any lights on your diagnosis unit if so you should have 4red lights and 4 green lights on that means you're eccs is working and 3 red and 1 green on your self diagnosis is working hope that helps cheers tim
