So I took my Silvia for a run today and the front and rear washers have stopped skooshing water.
There is no noise from the motor or pump at all. I think there is a leak from the bottle and it may have destroyed the motor. Thoughts and advice appreciated, please... |
Hi more likely it is the motor check it on the battery there rust inside the motor cheers tim
Hey Tim,
What should I check, exactly? |
Hi i took my washer bottle off and ran two wires from the battery to the washer pump if it works will buzz if no buzz no good can buy them easy from car shops or motor factors cheers tim
