Old 28-11-2017, 18:00
411454111 411454111 is offline
411454111 is an unknown quantity at this point
Default Pre MOTd today
I brought the car back without an MOT which is clearly not something that you should do at all, as I would usually advise against it. Anyways the car was as Adam (the seller) described and it drove all the way back safe and sound. The MOT tester commented on how clean the car was underneath and told me that the sills had been done well. (Adam did tell us about that, so fair play). The pre MOT test got a few advisories that were promising to say the least. (Headlights were off a little, a slight leak in the exhaust, play in the wheel I think he said bearing or ball joint) of which all will be sorted before it gets its ticket. I have to say that I am pretty chuffed with the result.
Old 11-12-2017, 20:55
tim murphy's Avatar
Welcome to the site cheers tim
Old 12-12-2017, 07:23
Default Thank you
Thank you
