Old 27-04-2006, 22:52
im not really sure bout symptoms of blow turbo, but black smoke is normally rich mixture (i.e no extra air when the maf says you are on boost) check the pipes between the turbo and the inlet manifold, if you are not intercooled, and still using the std cross over pipe between the turbo and the inlet, then the turbo end has a orange seal, this i think cant take 10 psi boost, and has prolly blown out.
there is plenty of guys on here that will tell you exactly what those symtoms are.
good luck
Old 27-04-2006, 23:06
Back Seat Chatter!
I replace that orange piece of shit with a proper silicone coupler.
I'll have to wait til the engine cools down before I can pick it apart...
I'm half hoping it's just that one of the couplers blew off, and I'm also hoping that I killed the turbo lols
I think I have an idea which coupler blew off if one did tho...
edit: I just checked and all the couplers are still on securely.
Old 28-04-2006, 21:10
Its quite likely if you have fitted a new inlet manifold recently that your leak is there somewhere. You will have a rising of rpm at idle with the throttle closed as the engine is sucking in air though somewhere
This will also cause your smoke on boost as once the inlet becomes positively charged it will loose pressure and cause you to run rich
Old 28-04-2006, 21:16
Back Seat Chatter!
checked around the IAA just now, and saw that a hose coming out of the IAA blew off due to a crappy clamp.
I replaced the clamp and put the hose back on..going out to check it right now.
hopefully that's the case, which I think it is.
wish me luck guys...I'll keep you updated.
Old 28-04-2006, 22:56
Back Seat Chatter!
its fixed...thanks for all the help guys.
Old 28-04-2006, 23:35
around the inlet itself was gonna be the next port of call, glad you got it sorted m8, there is a wealth of knowledge on this forum, best place to come to for info mods and tech.
Old 29-04-2006, 06:30
Back Seat Chatter!
heh actually, I hit up the whole S12 WAP and everybody pointed me in the right direction.
