Old 04-05-2006, 17:11
adzs12's Avatar
adzs12 adzs12 is offline
Forum Regular
Nice one kenny Although i have 6 frsh new helicoils in and studs etc, i have a feeling there still gunna come loose Did you have the same trouble and therefore opted for the allen bolts? How do they hold up compared to the std studs and nuts?
Old 04-05-2006, 17:20
kennyboy's Avatar
kennyboy kennyboy is offline
Default Allan bolts
Hello mate, the only reason i used them was cos i made the manifold so i could top mount the t3 but they seem fine. i use a very high grade thread lock fluid and they seem fine. Put a steady bracket on the manifold helps but i reckon you may struggle to do this on a standard one. i have always said its as much the weight and movement on the standard manifold that causes the gaskets to blow but mike at ferridays has a good point when he says the standard gaskets just can't take the heat from pure thrashing
Like i say mate your welcome to have six.f.o.c. just let me know. i had to cut mine to length but that not a problem.Four of mine are helli-coiled.
Old 04-05-2006, 19:56
adzs12's Avatar
Forum Regular
Sounds good to me mate , il pm you my adress later and its much appreciated
Your spot on about the weight issue playing a big part in the studs stripping the threads, seeing as i wont be opting for a top mount im gunna look into a brace of some sort to help support the turbo and reduce weight pulling on the maifold.
Old 04-05-2006, 19:58
I expect they may harden once they have been up to running temperature a few times
Old 04-05-2006, 22:03
yes i think a lots to do with the extra weight on the studs, with my turbo looking something like the dinosaurs ribs on fred flintstones car, i'am sure if i had not made a big brace that it would have stripped by now,
Old 06-05-2006, 23:10
Dont be petty
Old 06-05-2006, 23:12
adzs12's Avatar
Forum Regular
Originally Posted by Pukkasilvia
Dont be petty.
LOL petty? Im asking a question?
Old 06-05-2006, 23:20
oh ok your answer just seemed a bit like a retaliation.Nevermind.I must of mis-read it.Sorry.But the answer to your question is no. half the time it was at 14psi to get my turbo to last longer . towards the end of my 8v lumps past i didnt really care about the longitivity of the turbo and engine and gave it a beating.but it had a rolling road mapped 5th injector with controller box that allowed it to do much higher boost without underfueling.Did you think it was ok as i had run big boost?
Get a boost guage and then you will know if your boost controller is working correctly or not
So are you getting copper gaskets now or have you fitted standard ones again for the time being?
adzs12's Avatar
Forum Regular
I expect they will mate although that could be a good thing or a bad thing as they may just crumble.
Old 04-05-2006, 22:07
hey adz, you've ad me staffy barkin at those gaskets mines sound on the studs mate, i've got an 8mm thick stainless bracket that goes to the block.
