Old 09-05-2006, 19:43
i have a 65mm nissan throttle body for sale, it will fit straight onto the s12 manifold.
Old 09-05-2006, 20:41
Shaun how much difference does the throttle body make and where do you notice it most?
Old 09-05-2006, 20:50
well i think its at the top end when your needing more air, the more boost you run the smaller throttle body will slow it down,i know that i picked up 4cfm by changing the throttle body,if you have a t28 it stands to reason that you need a throttle body simular size to what car the t28 came off and i'am sure it would not be running a tiny s12 jobbie mate, the s12 tb is good for the standard boost on a t2 and thats it, its very restricted, if you are fittin an afc, you could do with fitting a larger afm as well.
Old 09-05-2006, 21:07
I have a safc2 unit ready to be wired in as i have the s13 injectors now and my walbro will arrive this week What afm are you suggesting?
