What are you marking up on the vernier pulley?
i've had increments marked onto the pulley for ajusting the timing.
Good idea, but you can't just move it 2 degs because you don't know if its spot on to start with.
Ideally the standard timing should be 112degs but if you've had the head or block skimmed (and) along with natural engineering tolerances you may find it still to be slightly incorrect after you've moved it 2 degs to 110degs
