Old 09-05-2006, 21:38
akira2_03's Avatar
akira2_03 akira2_03 is offline
akira2_03 is an unknown quantity at this point
Originally Posted by wacomuk
advance the timing a few degrees (ca20e & ca18et)
boost increase 2psi max without intercooler / with intercooler 8/9 psi increase (ca18et)
what you mean by advancing the timing a few degrees and for the boost i need the boost controler, right?
Old 10-05-2006, 18:33
wacomuk's Avatar
wacomuk wacomuk is offline
Ignition timing
the sayandard timing is set at 15 DBTC with standard boost you can increase this to 17.5 DBTC to give you a few more BHP`s and better off boost power. Always check for detonation!!!! After adjusting timing !!!
You can up boost afew different ways it depends on how much you want to spend.
1. Drill a hole in the pipe going from the turbo to the actuator. Start off with a 2mm hole then drive and check boost. If you want more boost increase the hole size. This is the cheapest way. This way will weaken the actuator tube ands possibly cause it to break, if it dose it could damage you turbo or engine!!!
2. Bleed valve. This does as above but you can regulate it vie a screw
3. Shorten the actuator arm. This will stop the waste gate opening fully thus increasing boost
4. Electronic boost controller. This is the safest to boost
Old 11-05-2006, 21:59
akira2_03's Avatar
sweet can't wait. im trying to get my s12 to be one of a kind in north america. one show car and one drift
1987 s12 => Under Construction
1986 s12 55k mint (ca18et)
