Old 27-05-2006, 10:24
akira2_03's Avatar
akira2_03 akira2_03 is offline
akira2_03 is an unknown quantity at this point
i kinda understand but im watching it now and its not at drifting its at accelating at high rpm building his speed before downshifting and all that other crap
1987 s12 => Under Construction
1986 s12 55k mint (ca18et)
Old 27-05-2006, 10:28
Back Seat Chatter!
it's doing it while drifting as well.
even at high rpm, if it's set to stock boost, and the BOV spring is too tight, then it'll do that.
stock boost is the same as our cars. around 7psi.
Old 27-05-2006, 10:39
akira2_03's Avatar
ok i get it thanks im a bit slow. lol
Old 27-05-2006, 11:00
adzs12's Avatar
adzs12 adzs12 is offline
Forum Regular
That s14 aswell as many high performance turbo cars will have an external wastegate and thats where that chatter noise will be coming from, on the other hand the noise can also be acheived by the air passing back through the turbo on such vehicles as ours only it will not be as loud and only really happen at low rpm as this is what i get. hope this helps.
Old 27-05-2006, 11:22
Back Seat Chatter!
really? external wastegates do that too? I thought it was only wastegates with weak springs.
learn something new everyday
Old 27-05-2006, 21:47
.Yep Adz is right.......plus, My external wastegate chatters like that as it regulates full boost aswell. It sounds pretty hectic. Although it doesnt do it at the moment as my silicon hose still isnt here and my turbo is screwed. £425 FOR A NEW T3 FROM TURBOTECHNICS btw
