you dont have to mess with the rods underneath,at the base of the wiper arm itself there is a single nut which probably has a press on cover over it,take the nut off then pull the wiper arm off the spline and readjust where you like,same on the back
oh i see. thanks for the info
1987 s12 => Under Construction 1986 s12 55k mint (ca18et) |
the wiper arms may be stuck on there really tight. Don't be afraid to use lots of force and wiggling to get them off.
its a 14mm spanner you will need, just put some pressure on the bottom of the wiper arm with your thumb, so when its undone it keeps the pressure even on the spline, then lift with the other hand, this will stop you trying to lever it off and break things
thanks for the help guys, i fixed the front and back wipers today. next up is switching the suspension and shocks rotors use s14 calipers and start fitting headlights
well change of plans for my engine. instead of sr20det i got a friend selling me his rb25det hope it works out great. swaping it will begin, was going to be next month but tight on time and cash so not too sure when hopefully in the begining of aug.
1987 s12 => Under Construction 1986 s12 55k mint (ca18et) Last edited by akira2_03; 25-06-2006 at 11:52. |
