stella?
wish i could remember!
the chattering sound is the metal flap on the turbo right.....when the air is coming out. im sure thats right.
thats what we were told when a mates cossie was set up. he he....every ones knows different
IM OFF LINE FOR A WHILE SORTING OUT NEW CAR/HOUSE/JOB
IM BUSY AS F**K |
No its the air stalling the compressor blades. As basically the compressed charge reverses back out of the turbo.
It causes stress on the shaft as a result. I personally wouldnt bother with a dump valve under 20psi. There arent many on the market which do a good job anyway, most are designed to be loud. |
But the the dump valve also helps to prevent stress on the shaft i always thought
Yeah but its not an issue unless you are running high boost like 20psi plus.
this debate was had some time ago but i cant remember the company that tested it.
they took 2 cars, same setup, one with dv, one without. and over a set period of time tested the turbos for wear etc. both wore equally. as martin says, was around 18-20psi plus that it became an issue due to the higher pressure. but then this would then depend on the unit you are using as most uprated units can take more abuse than a factory standard unit anyway. my old red one used to chatter well. all i did was fit a k+n filter and upped the boost a bit. |
