Old 08-06-2006, 21:50
serendipity123 serendipity123 is offline
serendipity123 is an unknown quantity at this point
turbo seals would maybe sound possible, now where would i buy some of them ? is it important to change them ?
Old 09-06-2006, 01:39
Its most likely to be turbo seals, you can rebuild it yourself by buying a kit like this from ebay
http://cgi.ebay.co.uk/Garrett-T2-T25...QQcmdZViewItem
And use the guide in the how to section of this forum.
Old 09-06-2006, 08:10
i really wun't advise rebuilding your own tubby, it will cost you more in the long run,for the price that a recon t2 will cost you its not worth it
Old 09-06-2006, 08:39
if there in the turbo i doubt its the prob as its a brand new unit £500, hasnt even been on the road yet.
Old 09-06-2006, 10:43
What turbo is it?
Old 09-06-2006, 13:27
When does it puff oil smoke from Cold/hot ? if the Turbo is New then I would say this can be ruled out. The other Two things it can be (like Shaun said) Valve stem oil seals or valves Guides probably Exhaust side as they wear. Or Oil rings are worn which may Not show up on a Compression test. If its from Cold I would bet on Valve Guides or stem seals as oil could leak down them overnight and are burnt off when the engines started.
Old 09-06-2006, 20:33
i have a mega squirt ecu and the car does it when its warm just after giving it a bit of large on the throttle, gives out quite a bit of smoke then after a 10-20 seconds its clear again, its a really strange one.
leave it to cool and its fine again
