Old 21-06-2006, 19:49
johnny johnny is offline
johnny is an unknown quantity at this point
Thanks for all the replies, I'll have a poke around the engine bay at the weekend.
Old 22-06-2006, 00:02
Its probably an incorrectly setup throttle position sensor
Old 22-06-2006, 08:24
Thanks 30psi, how do I adjust the TPS?
Is it just a case of winding a screw in and out or is it a little more complicated?
Old 22-06-2006, 08:49
You adjust the pivot of the sensor so that the switch is shut at idle. As soon as the throttle is lifted off of idle the switch is opened.
There is an idle adjustment screw but I would check the above as its usually not setup properly if the throttle body has been removed.
