Sweet will have to try that then! I have tryed so much to fix the lights but they just wont to down. when lights are off. and i think its making my battery go flat as well. the motors do work tho as when i wind the lights UP they reset and go down then back up again. allmost took off my thumb finding that out lol. if anyone has any ideas at all i would love to know. also changed the relay and still nothing.....
[center] ![]() Nissan Silvia S12 - CA18ET |
may sound obvious but have you tried usinga known good stalk control?
i have had a faulty one play merry hell with my lights... dont bother asking nissan for a new one though... as i recall it was in the region of £200
well even the little switch on the dash does not make the lights move. it works if they are wound down. (makes the lights goes up)
shame the stalk it not the same as the s13's as my friends have loads of them lying around heh
Its looking nice.
There is a headlight relay behind the drivers headlamp. Maybe that has poor wiring connections or it is sticky.
![]() Quote:
is that the one behind the battery? as i have changed that one allready. also i was told there was one behind the dash but i could not find it. will probably find out its wireing. also does the ecu have anything to do with the lights?
also if anyone has a wiring diagram picture of the lighting system i would love to see! heh
