i have a T25 that i have to get reconed, but for the conversion i dont have an elbow for it, the T2 one dont fit, but does a T28 200sx one fit the same as the T25 200sx, i have seen a T28 one, i just need to know if this will do what i need, or does anyone in here have a T25 one for sale pref near essex
![]() Cheers.
Yes a T28 elbow will fit the 5 bolt pattern. I have heard thought that a T2 one is better but you would have to get a lug welded on it to fit !
its a bit hard to weld a lug on, coz it is cast, it wont hold, the weld will crack straight away.
but i saw a T28 one on ebay. cheers for the info.
go on sxoc and put a wanted ad up for a stock s13 downpipe. They go for about £15
i must have read your mind, i just did that before i checked back here.
cheers
is there a difference between the s13 elbow and the s14, coz a guy has been in touch, he bought one for his s14 T28, but said it dont fit, but i think he got it from a guy that had a s13, is there a difference as i thought the T25 and T28 had same bolt on parts.
Cheers.
there may be a difference. I would wait until you have a dead cert on an s13 downpipe,Its not worth the hastle.Theres loads around.
![]() Quote:
this one is a trust high flow jobbie, afaik, it came of a s13, and wouldnt fit his mates s14, looking on forums, it seems there is a difference in the angle, thus this should be ok for my one. im looking to pick it up tonight.
will keep ya posted
Sounds good
![]() Quote:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA%3AIT&rd=1
i got it, it is identical to this one but the s13 version, never been used £25 bargain, just gotta get a lambda plug or ill take it into work and weld it up as its stainless. only issue i may have is my exhaust has the beveled end for the T2 elbow, and this i think is for the flange to flange type, but i shall see, and modify to compensate.
