Nice...
I got hold of this brake line crimping tool so made a new section up for the micra and bled the fluid after, and some pretty awful crap come out. |
![]() what the car inside the arbour ??
www.clubS12france.com |
without nitrous it was 260 something at the fly 209 at the wheels. The nitrous pumped the wheel figure up to 290 something and mid 300s at the fly.thats very respectable seeing as it was 30+degrees at the time and they let it cook on the rollers for 20 minutes before they did the run.But the actual rollers seemed to be reasonable
If the car had been run up to temp 30 mins beforehand and then left and then started just before the run it would of done alot better.I suggested this but it wasnt done. I think they were a bit amature(it wasnt thor).
these figures will change for next year.
the first run (216 at the wheels) he only reved it to 5000rpm. i told him to rev it up to 7000rpm for the 2nd run. 240bhp at the wheels. 3rd run with nos. 294bhp at the wheels gutted. leaving the car to cook for 15 minuits before commencing, then only to find they DIDNT use a fan whilsed dyno'in was a big power sapping contributing factor. couldnt beleve it.! sucking in 34c temp without a cold air sorce. madness.! gunna go back to the drawing board & see what i can do for the next JAE. want to re-create a bit also.
I saw a lot of other things in your bay which I think would be restricting power personally, I'd love to have a play with it and try a few things. if you want an accurate power figure you need to get over to Surrey rolling road. their Dyno-Dynamics is becoming the benchmark |
whats the engine spec as a matter of interest? ET or DET etc? boost level, turbo? good numbers
what other things did you see that were 'restricting' power.. were did you see them..?
