Old 27-07-2006, 19:34
Chaange the ECU and you have to change the Auto ECU which is inside the Nearside/offisde 1/4 panel. Access can be gained by taking out the rear speaker. You can use the same Throttle position sensor TPS just disconnect the second plug which is for Full acceleration. Remember to take out the brass collar when you change to the Manual flywheel it sits in the middle of the crank!.
Old 28-07-2006, 08:01
damo666 damo666 is offline
damo666 is an unknown quantity at this point
Default ecu
When u say change the ecu in the back.do u mean just disconect it or will my mk1 manual have an ecu in the back 2?? ta
Old 28-07-2006, 12:54
Change the Normal ECU (auto one) in the car for the manual one, then disconenct the ecu thats in the rear 1/4 panel which is for the Auto tranny.
