Old 08-08-2006, 19:44
On most turbos you need to undo the housings slightly so you can rotate the centre section to positions that work for your fittings. Its not nessessary to use the water lines although if you can get them to fit its better.There there to help reduce heat transfer from the exhaust housing to the compressor housing and increase durability but many poeple dont the water lines at all(including myself) and its works fine.
When did you go det?
