The silvia had developed a starting problem, somtimes it would take an AGE to start, then run lumpy for a while and then would be fine,
So I have replaced plugs, leads and dizzy cap. The thing is I have had to remove the dizzy to get the cap of as the screws were rounded off. Now i replaced the cap, checked the leads, checked ALL the timing marks and the mark on the dizzy but the car wont start. Here is the timing checks i made. Bottom pulley, TDC Top pulley (cambelt top cover removed) timing mark at the top Dizzy Punch mark aligned, rotor arm pointing to #1 We have a good spark and lots of fuel, everything is aligned, all eartha are good all cables connected, can anyone help? Thank you T
1985 Mk1 S12 |
Terry posted you on ZXOC !
i too answered on ZXOC
Thanks guys, its still not working tho
1985 Mk1 S12 |
Updated now.
The punch mark on the dizzy can be confused with a stupid assembly pin on the dizzy if your not familiar with it
![]() Quote:
