how is the dump valve condition, when my valve went tits up, that gave erratic idle and missfire.
![]() PS - Got under the car last night - The water feed hose from the turbo had been melted through - Just caught it in time, as the coating on the protective heat blanket had worn through, and contact with the turbo had scorched through to the inside of the hose in one tiny point... Have replaced it with some more hose, and now looking for some more (better!) heat wrap... (was a real bitch to get to though!) - Will fix this, and then try to sort out another alternator... Hopefully I'll be nipping up to God's either next weekend or the weekend after if all's well! (Must check with God first though... ![]() Fingers crossed I guess, but the battery that I put in last week's already lost all of it's charge, so that's ominous too - Probably got a short or something somewhere, but hopefully SG will sort it out along with the other problems! ![]() Thanks to all of you for the advice and sugeestions - It's well appreciated! ![]()
Only 450+ BHP from a 1.8? (Well, until I can run big boost again ![]() ![]() Yep - I fookin' love me beast ... |
![]() BITCH to get the alternator out, but nearly there - It's a bit tight in the ol' engine bay - lol!... Found a place near me with one on the shelf - Re-con for £88... - Sound reasonable?... (Wanted £40 for fitting though, so f*ck that!)... Should be winging my way up to Silviagod's for a cuppa in no time at this rate! - lol! oh... erm... as soon as I get my clutch sorted that is! - The pedal was on the floor again after a week sat around, and the fluid was empty - Will grab a slave cylinder pronto methinks, and get under there again.... ![]() It's all good stuff though - I've become a bit braver and better off as a result of the advice and help from you guys, so I'll be buying some helpful people pints at the next event methinks! ![]() Cheers, Den. PS - Car ran smooth while I had it hooked up to the booster/starter, and died the moment I cut the booster off, so pretty much shows that it'll be okay once the alternator's in and the battery's either replaced or charged up again.... I'm a happier chappy than last week... ![]()
excellent....... If you have an old s12 mk2 alternator lying around you could fit that.....
I found i had a broken wire from the alternator to the battery so i ran a new wire straight from the alternator-----(the nut terminal)(as theres too fittings on it)--- to the battery positive. It sorted mine out. Yep the det alternator is a bit of a pain with the bigger inlet manifold above it and all the pipes.I had to change mine at the roadside in the pitch black with my cigerette lighter once and the rest by feel.it was in december and i couldnt even do it by feel by the end of it as i was numb. Really wasnt pleasent.I have a hate for changing s12 alternators for life now Roscoe is pretty good with electrics etc. A trip to his would be better than going to norris in my opinion. You'd have your clutch and all sorts fixed in no time and be fed cups of tea aswell ![]() Id be interested to know what clutch hydraulic piston Norris have put on your belhousing Maybe Paul can have a closer look.It may be a s13 or s14 one. My cylinder still needs bleading and i need to do my gearbox oil too.Its on my to do list along with everything else lol
![]() Cheers guys, I'm a lot happier now (and I didn't waste another £88 of my hard-earned on another needless alternator!)... ![]() Now all I have to do before I can proceed with my mission to SG's is to bleed the clutch again ... ![]() t even pump it back to life, so it's gonna be another bleed job I guess - Will grab a new slave cylinder from Nissan if they're def. only £21!... ![]() Nice one all who helped me!... ![]() Den.
great you got it sorted m8
