Old 20-08-2006, 22:26
Have you done anything to the engine since you have bought the car?
Old 21-08-2006, 19:45
FLEXXX's Avatar
FLEXXX FLEXXX is offline
no nothing its been parked up since ive got it all i do is start it up every other day just warm it up as im just waitng for some cash so i can order the springs so i can fit the new kyb shocks and grooved discs at the same time will start the car up later this evening and report back on the level of smoke i did realise a small hole from the rear of the exhaust smaller than a 5p piece
Old 22-08-2006, 13:43
FLEXXX's Avatar
ok ive just took off the pipe between the throttle body and turbo on the turbo end there was a small oil puddle in the orange rubber neck is this normal or not as for tghe white smoke it is still there i will get some more fuel and some redex and see what happens as it has been parked up for 6yrs or so apart from that all is well it starts first time the interior is mintas is the body everything is in good order apart from this but youd expect a few bits
Old 01-09-2006, 19:36
Redon Redon is offline
S12oc Newbie
Redon is an unknown quantity at this point
Default Smoke
It might be the thin pipe is cracked. Its a pig to replace. Very difficulyt to get at. It driops oil on to the hot manifold and makes smoke. My mechanic made a new (colied) pipe and fitted it. Mind you, my turbos just started sounding like a fighter jet on take off...high pitched whistle.....?
Old 01-09-2006, 20:09
FLEXXX's Avatar
what thin pipe mate do you mean the pipe between the throttle and turbo mate if not what pipe mate cheers
Old 01-09-2006, 22:24
FLEXXX's Avatar
http://cgi.ebay.co.uk/GT28R-Dual-Bal...QQcmdZViewItem
will this fit and is it any good on a s12 with std internals and ss zorst,air filter,fmic not forgetting better clutch etc
Old 02-09-2006, 09:16
looking at the size of the housings, i'd say it would be to big,my t34 has smaller housings, mines a 58 and a 50, so on s12 managment i'd say to big mate.
