Old 07-12-2005, 23:33
adzs12's Avatar
adzs12 adzs12 is offline
Forum Regular
But how do you expect the filler to take to rubber
Old 08-12-2005, 19:24
E11's Avatar
E11 E11 is offline
E11 is on a distinguished road
it does not need filling just rub it back prime with a a paint that will stick to rubber fine and just spray desired colour
no point doing a half arsed job do it properly and it will look good
Old 08-12-2005, 19:33
Adz is right here. you need to take it right back
If its cracking in places now i recon it will continue and it will end up a mess in the end. Do it properly and rub the bad areas right back. It should look much better as a finished job this way
Old 08-12-2005, 21:34
S12KWA S12KWA is offline
S12KWA is on a distinguished road
If its the same type of rubber as the standard one its not ment to be painted.
Paint shops/ body shops use a special plastic primer 1st to prevent the paint
from cracking.
You will have to remove all old paint and start again to do it properly, this will be a nightmare.
Try a jet wash 1st to try and bring the paint off or if you know anyone who works in a body repair shop get them to try with compressed air.
If not you will have to sand it off.
Old 09-12-2005, 00:34
ProfoundSound ProfoundSound is offline
ProfoundSound is on a distinguished road
if it is rubber you have to use paint with elastisiser (excuse the speeling)in it. This allows the paint to stretch without cracking. Beware tho as painting that mixture is a C U Next Tuesday!
Old 09-12-2005, 16:22
adzs12's Avatar
Forum Regular
Personally if this is a standard silvia spoiler a jet wash will blow it to pieces lol, even if it was brand new let alone 20 years old.
Can i ask why you are going to so much trouble as to painting a rubber spoiler?
If i was you id spend my money on getting a renault 19 spoiler or pug 405 from the local scrappy and paint that instead.they Look much better and will paint alot easier as they are not rubber.
Old 09-12-2005, 16:37
Ronin's Avatar
Ronin Ronin is offline
Silvia Driver
The reason I've said it's rubber is that the the edges are spongey, it's pink in colour in it's "raw" state under the paint. There's only small patches of cracking, damaged in transit I expect, as i said I was going to fill the cracks in the paint then spray with primer, now I may strip it right back and spray with a plastersizing primer ( I've seen some for plactics/rubber that stretches with what it's sprayed on ) the top coat it. But it's going to have to wait till after xmass now I'll let everyone know what happens when I've done it.
