Old 31-08-2006, 22:33
wacomuk's Avatar
wacomuk wacomuk is offline
or the turbo blades have been damaged
Old 01-09-2006, 11:52
or could be an air leak possibly from that very thin pipe that goes from the joint at the brake booster to the Boost sensor near the turbo
Old 04-09-2006, 21:42
screaching is normally the turbo gasket just before as previously said it blows the gasket out and sounds like a tractor lol .
Try nipping up the 4 nuts up before she blows with a 13mm spanner
The nuts normally come loose because when the turbo has been changed the washers with tabs are not refitted before the nuts . ( they have tabs on them that bend down round the nut to stop the nuts coming loose)
