Old 06-09-2006, 10:29
tim, are you going to get your ass outside and do the job then lol, no use sat thinking about it .
Old 06-09-2006, 11:34
your a lucky chap if you have lasted this long without ever having to remove it before
Old 06-09-2006, 11:38
bigtim's Avatar
bigtim bigtim is offline
well its took about 40 mins and its nearly off,one bolt to go at the back on the bottom of the manifold all turbo and other bolts are off,bit of a roll.
came in for a cuppa.
Old 06-09-2006, 13:16
Told you it was a fiddley bolt !
Old 06-09-2006, 14:39
I got a special spanner for that pain in the arse nut
Old 06-09-2006, 16:06
bigtim's Avatar
sorted,one bolt is looking dodgy as its not solidly tight and keeps turning which is a bummer its tight but wont lock tight and i can see the bolt coming out.
I guess this first pic is why the turbo gasket was blowing,or though this is at the back and the leak was at the front gasket was in two.
This pic is why i changed the manifold in the first place as it was leaking out this crack on top,
All off,oil is from dizzy seal which is on the agenda next
All done,dodgy bolt is top left as you can see its a bit longer,just hope all the others keep it in check.Doesn't seem to be blowing anywhere when i fired it up so fingers crossed.Biggest pain was getting the locking tabs done up one still needs doing.
Big thanks to Shaun for answering his phone every time i called and my 13 and 14mm stubby spanners which with out there help non of this would have been possible.
Old 06-09-2006, 16:11
feckin hell tim, that manifold was well shagged, even the bit that i ported out of the one i sold you has cracked, i wonder where that ended up
