Im running 8 kg/mm on the front which is same as 447lb.
I'm expecting to get softer springs. You really will find it too hard on the front. Certainly will be a miss match as is probably at least twice the spring rate of the rear. |
i'll probley uprate the rears to coilovers and change to stiffer as well, that bart guy reckons his aint to harsh, but i'am thinking of the weight of the fj, its about 188kg.i've had solid mounts made for the fj and it sits it about 15mm lower with no clearance issues.
Just go careful when throwing the car down a slight bumpy B road. Bart doesn't have them in the US of A.
That spring rate is suitable for race tracks that almost perfectly smooth by the way. How much heavier is the FJ over the CA. Is it about 40kg? |
i think the ca is 118kg mart, i think either northener or wacomuk posted up somewhere, i could be wrong, i usually am lol.
,the mk2 they are going on is being used mostley for track and straight lineing, i think it will be undrivable for the town.
I was looking into getting some short (12" for arguments sake) fully adjustable coilovers from GAZ/Spax or tein, something along those lines and mounting them where the standard rear spring sits. Not sure if anyone has tried that yet or if anyone knows if/why it can't be done
if you go on clubs12, then onto brakes and suspention, do a search for coilovers, it will come up with bart j, he's welded the threaded tube to a plate and fitted it to the rear suframe, where the originals fit, he's used springs like i'am using on the front, the fit in there.
Thats the same as how SE did it
Thanks mate
i ground a spring cup off today and tried to put a tube on, but there's no way it will go on, the tube is about 2 tenths of a mm to big, i was speaking to someone who's mate did his own conversion, he said that he had to heat the threaded tube up in the oven and leave the strut in the freezer overnite, any advise martin ?
