  #14
Old 18-09-2006, 07:06
dickies12 dickies12 is offline
S12oc Newbie
dickies12 is an unknown quantity at this point
Originally Posted by JackieFan
Suspension is straight forward..
£96 for some lowering springs from AVO ([url
www.motorsportworld.co.uk[/url])
Plus Monroe do replacement inserts for the front at £86 per corner and the telescopic on the rear are £36 each
EDIT - http://www.nissansilvia.co.uk/vbb/showthread.php?t=1123 Northerner is getting shot of some Monroe inserts for the front
got to be said you lot are a friendly bunch on here, i wasn't expecting people to go to this much trouble on my behalf being a newbie and all, so thanks it's all much appreciated!
the back box i think i can handle now you've said about just cutting it off and welding up a straight through pipe, probably the best option.
it's the suspension thats got me intrigued though has anyone got pic's or measurements of the front shocks (inserts) and their top mounts please? also measurements of the springs (length and diameter)? and if theres any available of the rear that would be spot on to.
i have a dead golf gti with insert suspension thats covered all of about 6feet since fitted so its mint. if it measures up then i think i could give it a try. also got a set of springs from avo for a crx that i could hack about. might drop them a line to see if their the same.
cheers
