Old 25-09-2006, 12:41
Originally Posted by datdrift
i changed the clutch pressure plate few weeks ago for a s13 exedy one, but the clutch cover i got with it dident fit so ive still got the old cover on....
how much do you reckon the steering rack bushes would be?
as for cambelt.... ive not done one before, but i suppose it would probably be a good idea to do it
I think S13 bushes are £40, but don't MMR do them? I think one of the s13 bushes is different though.
As for the clutch cover, I'm surprised it didn't fit. This is what makes it better over the S12 clutch. The S13 clutch has a clamping force of 550kg opposed to the 450kg of the standard S12 one.
I would try to change it again when the engine is out
Old 25-09-2006, 12:47
datdrift's Avatar
datdrift datdrift is offline
yes mmr do one of the steering rack bushes i think, but i'm not sure if it would fit, as there cars are LHD?
i only paid £30 for the clutch, so i think its got the wrong cover with it, as it doesent fit onto the locating dowels....i think i should be able to get hold of a used standard s13 clutch cover for free of someone tho, so i could fit that
Old 25-09-2006, 22:04
Nice bit of info there............thks
Clutch release bearing
engine mounts
clean the engine bay
tidy the wiring loom and clean contacts and terminals
change oil filter
Old 25-09-2006, 23:33
the clutch you have isn't for a KA24 (240sx) s13 is it? if so you can make it fit with a bit of careful hole slotting
Old 26-09-2006, 11:49
datdrift's Avatar
the clutch might well be for a ka24, ive been trying to think what else it could have been for, and that sounds very possible?? heres a couple of pics of it, the first one its under a standard s12 cover, flush at the top to show its sliightly bigger, and the second is of it on a s12 flywheel, the 2 top dowels are lined up and that pushes the other one out this much.....so i might have to try some careful slotting on all the holes? i was just gonna do this before, but dident want to unbalance the fly.....
Old 26-09-2006, 12:01
datdrift's Avatar
also i might as well pull the sump off and clean the bottom end, and maybe have a look at fitting the det crank girdle?
Old 26-09-2006, 12:19
good idea really,ive found engines with partly blocked strainers before and you can get rid of any crap in the bottom of the sump too
Old 26-09-2006, 12:36
I wouldnt take the sump off if I was you. Your engine is very clean inside anyway, so I wouldn't worry about it.
I think being a high rev drifter your engine would be more likely to throw a rod then have an issue with the crank.
