how difficult was it to get the cast iron manifold welded? i thought it was hard work to weld cast iron?
it was pre-heated then welded with special rods, nickle i think, i could be wrong.
Thats pretty good shaun. Well done. Nice to see new things being done on et parts. The location of the wastegate outlet isnt too bad either considering whats there to work with
cheers jon
how did you make the hole for the external wastegate?,did you burn it througth then round off the hole or something or use a holecutter
