i'am here again, another thing is , pete rosenberg should admit defeat, settle is debts and actually appologise to his costomers, then actually make an appearece, because at the end of the day he must of liked the s12 to start and modify them, come on pete come and let us know the whole story of the s12 and why.all said and done he made a good job of my engine.
I did get hold of the Silvia engineering cossie intercooler kit, but we chopped it up to fit it to the turbo beetle. The silvia that it came from had a metal duct going to the intercooler, so it prob worked nearly as well as any of our front mounts.
He didn't actually go under. He decided to actually close shop and call it a day. He had a problem with the council at his premises. He had a few cars and used to park some outside during the day to which they got the arsehole. Eventually they forced him to leave, and then he decided to finish off the current work and not take on any more. I wonder where all the other s12's are that had major engine work done by SE...
I only got a increased boost kit from them. Which turned out to be some
rubber piping and a metal T'piece for around £60-70! Phoned them twice 1st guy was helpful 2nd guy was NOT. Iam just wondering were iam going to get a 5th injector kit etc from now? i have been told that running 12p.s.i from 4000rpm up the silvia's injectors are working flat out, more boost/power requires more fuel hence the 5th inj they used to sell. They used to sell the cosworth intercooler kits or a front mount type with a radiator relocatoin kit. Also a copy of the factory bootspoiler in fibreglass etc I think P/R also used to race silvias years ago hence all the parts/knowhow. |
who are p/r, i would not bother with the 5th injector kit, i had one, it was overfueling a t25 at 18psi and i had the full spec engine that i'am running now, they used a ford cold start injector with a metro oil pressure switch, it came on at 5/7psi, i'd say if you had to use one, have it come on at about 16/18psi through to 22psi on a t3, this would still overfuel, but would protect it up the top end and cool the pistons, i have mine set up to run rich up the top, this is what andy @AMT engines has done, so that i can run a flat out top speed run, this can bugger the plugs up, in japan they run the 300zxtt that rich that they have to change the plugs after every run.
The cold start injector never seemed to add much fuel in my opinion, it only gave out a fine little queer mist. If its designed to enrichen an engine a bit at 1000rpm, I doubt it has much ability at full throttle at 6000rpm. The 5th injector was a waste of time, it did nowt for me.
Why are you having it run so rich at the top end Shaun? You lose power when its too rich.
its not mega rich, but if you where to run full out on a top speed run for a mile and a quater, its better to run richer to cool the pistons, a lot of the top tuners run rich thats why you can see them poor the black smoke out on full boost, i do more long top speed runs against scoobys than the old traffic light grand prix's against nova's,its just sensible to follow the proven methods
Do you know what ratio you are aiming for?
