Old 15-10-2006, 09:10
s12Rob's Avatar
s12Rob s12Rob is offline
Originally Posted by Pukkasilvia
Here is a brief guide to improving the general engine performance and drive of your s12 Silvia.
C109 OIL FILTER and 10w-50w fully synthetic oil is the general recommendation
Larger Turbos such as hybrid units, Cosworth T3 turbo? s or T28 turbo? s can be fitted. These will all have different Powerband characteristics. I have tried a t3 on a standard engine and found it had a bigger power band slightly higher in the rpm range
where can you get these oil filters from and whats the difference with an oe one. and with the turbos, will the t28 bold on to the std manifold??
Old 15-10-2006, 10:40
Halfords or any motorfactors will have those oil filters and the t28 will bolt straight onto the standard manifold
Old 15-10-2006, 11:01
s12Rob's Avatar
cheers m8, that will be done soon enough, need more power at less boost. lol
anyone got a safc they want to sell
Old 15-10-2006, 16:40
nots13 nots13 is offline
nots13 is an unknown quantity at this point
whats the maximum bost pressure you could run without an intercooler?
1991 Lexus Soarer twin turbo....320 lb/ft from 12psi of boost!! bye bye m3
Old 16-10-2006, 16:44
s12Rob's Avatar
safe i wouldnt go much more than 8 if u have a heavy right foot, it you set the timing up you can run more to stop dett
Old 16-10-2006, 19:25
10psi. After that the inlet temps rise too much and kill any benefits of increasing the boost and so this levels the power out. Fit an intercooler and then you can winde this up by an extra 4psi with a very healthy standard Turbo.
Old 15-11-2006, 18:31
smoker's Avatar
smoker smoker is offline
Default C109
Sorry if this is a stupid question ..doh! but what is a C109 oil filter ?Is that a Fram/Nissan part number and does it have bigger capacity than std. filter ?
Old 15-11-2006, 23:56
Thats a champion oil filter which is an alternative supplier. Its identical to the Nissan item. Halfords stock these
Old 23-02-2008, 19:15
323ian 323ian is offline
Is there a fuel pump available of another car which can be used instead of a wahlbro? ie a skyline one or something?
Old 23-02-2008, 19:19
ive heard of people using a 300zx pump, it should do the job as they are 280bhp as std and i bet you can tune them a bit before you have to change the pump.
