Old 18-10-2006, 17:48
ive had a look at this, but its been dark both times which hasent helped......and everything seems to be on fine its a low mileage minter with NO rust anywhere, all the connetors look mint etc.....it just turns over and sometimes coughs into life for a few secs then dies.....i pulled the ecu out to see if it would give any clues and all i got was a 44, which i belive means OK.
any ideas
edit; oh yeah and its a compleatly standard auto, stock boost everything
Old 18-10-2006, 18:58
If its nothing of the above and you definatly refitted everything you removed or had popped off then its got nothing to do with it and you need to test everything from scratch
Starting off with......
Is the battery and alternator outputs ok
Have you knocked a dizzy connector off or damaged you king ht lead etc
Then go through and check every connector and join you see and try different air flow meters,coils if you have spares etc
Old 19-10-2006, 16:52
honest_jim honest_jim is offline
honest_jim is an unknown quantity at this point
There are 2 fuse links that run off the battery its worth checking these. Check them with a test light but move them around at the same time to ensure they dont cut out with vibrations. The connectors can go bad but its an easy fix.
Old 23-10-2006, 17:31
jakezx's Avatar
jakezx jakezx is offline
jakezx is an unknown quantity at this point
still working on hopfully havin some look at it soon to see what they think tried all the above still no luck dont have a test light though:
Old 24-10-2006, 14:30
jakezx's Avatar
Thumbs down
still no luck got the day off and trying my best to get the silvia going but still no look help. cheaked ht leads seem ok and the dizzy cap and bost pipe again and all the fuses also the air flow pipe and connectors but still wont fire cannot get the sparks out cannot get spark plug socket down the tight gap
Old 24-10-2006, 14:39
Fuel pump?
Old 24-10-2006, 17:51
don't think its the fuel pump, it makes a noise, and the fuel can be smelt after cranking the engine, almost seems like its flooding......
