Old 19-10-2006, 23:27
well done
Old 19-08-2009, 18:29
looks like i may have to do this as well as the new turbo, thank fully once i got the turbo off, i could feel it has lots of play, so im confident i havnt spent that money for nothing,
but apon checking, i have found oil running down one of the valves, possibly 2, cant see inlet side, i have a set of stem seal already in a HG kits i got for the rocker cover gasket.
so i can get some rope or similar, what i need is a spring compressor, what did you use, is there a part i can buy to do this for me, like the ones you used to get for the ford pinto engine, although they used compressed air in the plug hole.
Old 05-06-2010, 02:51
Time to change on mine too.
What tool did you use?
Same thing as in the "supra how to"?
Old 06-06-2010, 02:53
No I used a valve spring compressor that clamps onto the actual spring
Old 06-06-2010, 13:53
Thanks mate.
Old 31-10-2010, 21:30
Hi, guys.
I tried to do this, this afternoon and i'm in trouble now.
I used this:
I can't compress enough to remove the keepers.
I also notice that when i compressed it, the spring isn't loose enough, it compress upwards, i mean that the spring retainer don't go down like the retainer and keepers stuck.
And i also notice even i'm at TDC the valve can move like 0,5 cm down the piston.
Must i use some rope?
Thanks in advance because i need to fix my car for tuesday.
Cheers.
Old 01-11-2010, 20:32
I used a air valve holder and a sealy spring compressor when i did my corvette oil seals. The air hold tool makes the job very easy
