Old 31-10-2006, 09:25
there shouldnt be any play really,its a quite a job doing them involving taking the arm off ,undoing a bit nut that is done up somewhere around 215 lbs ft or more,and pressing the old bearing out and pressing new one in,you need a bench and large vice if your gonna do it otherwise i would give it to a garage to do if they need doing
Old 31-10-2006, 13:48
smoker's Avatar
smoker smoker is offline
Thanks for reply it's not looking good, has anyone here had their car pass an mot with slight play in rear wheel bearings ?? Does the FSM mention any allowance for play ?? cheers
Old 31-10-2006, 14:08
drop the drive shaft off the wheel end, then borrow a talk wrench and set at 289ft/lb, then see if the nut that is inside will tighten anymore.the shaft has 6 x 12,, bolts.
Old 31-10-2006, 20:28
a very slight movement may get through. Just give it a go at a friendly Mot station. They may not need replacing, just need repacking and nipping up slightly
Old 01-11-2006, 00:16
smoker's Avatar
Thanks for that i'll try giving the nut a tweak sounds alot less hassle than dropping the suspension arms etc.
Old 01-11-2006, 00:20
adzs12's Avatar
adzs12 adzs12 is offline
Forum Regular
Yeah wheel bearings can live on if you repack them with grease
Old 04-11-2006, 18:22
smoker's Avatar
Well the car passed it's mot on friday after adjusting the co and headlamps so i'm legal for another year.. didnt seem too concerned about the wheel bearings so i'll repack them when i get time. Can't wait to get the engine run in so i can turn up the boost it's only runny 9 psi at moment on a T25 but still goes like a rocket .
