Old 29-12-2005, 22:20
Sounds silly but maybe your battery is just nackered? check the water levels aswell as putting a multimeter on the disconnected battery at night and then rechecking it in the morning to see if what charge its lost whilst being disconnected.
Check things like the interior boot light is switching off,maybe the alarm is not functioning correctly if you have one fitted, or maybe your cd player is not switching off properly and an amplifier for a subwoofer is staying on etc.
Old 30-12-2005, 08:08
ramzb's Avatar
ramzb ramzb is offline
I've tried a few different batteries, it's a brand new one on at the moment. Once connnected it'll only last about 4-5 hours before it's flat, leave it overnight and it's as if there is no battery.
Old 30-12-2005, 09:22
reece's Avatar
reece reece is offline
reece is on a distinguished road
Hi m8'
Just a thought, Have you checked the boot light to see if it is turning off with the the boot is shut?
Old 30-12-2005, 14:55
ramzb's Avatar
Tried all the obvious things like lights etc, even pulled all the fuses and it still goes flat overnight, something is draining all the current but can't find out what.
Old 30-12-2005, 15:12
Dr Silvia's Avatar
Something is draining your battery thats for sure.. disconnect 1 battery terminal and use a multimeter to get a current reading with the ignition off. This will tell you how much current you are using with the ignition off.. not sure on what a 'good' reading would be but suspect under 3 amps
If that checks out fine then chances are its your alternator
Have you measured battery terminal voltage with the engine running? If it reads 12.5v then check the alternator output
terminal 'b' (+ve); measure the brown insulated terminal with 10mm nut to earth.. Should be 13.0 - 15.9v if not, its shagged
Old 30-12-2005, 15:32
You can try disconnecting the fusible links, in the little black box near the battery.
This will prob stop the battery dying. Then use the multimeter on the terminals to see where the current is being drawn from.
One thing for sure is...
Its only a simple thing thats causing the problem. Its finding it thats the pain.
Old 30-12-2005, 15:54
ramzb's Avatar
OK, thanks for that, I'll try all that tomorrow, give me something to do in the morning before getting totally rat-arsed
