Old 18-12-2009, 18:57
the covers are different too.
Old 19-12-2009, 07:38
Draconis's Avatar
Draconis Draconis is offline
Wait a minute... You guys poking fun at me? lol How is the cover any different? I am basing my information off of what I've seen and have of MKI and MII setups. I wonder if you Euros have different setups.
Old 19-12-2009, 09:45
i'am sure mk1's and mk2's are slightly different, i'll check later as i have both.
Old 07-01-2010, 23:01
ok, i finally got outside to take some pics, my surrounds have little cut out in them and the grille ends poke through, and the screw just a bit further back is what secures them on, you will see one side of mine is cracked , still seem secure enuf.
let me know if you need any more.
Old 08-01-2010, 08:45
Draconis's Avatar
Those pics are just what I needed. The only thing I could ask for is someone to take a pic of the headlamp without the bars and the surrounds so I can make sure that they are still the same setup as what I have over here. Otherwise, I guess I'll be looking to purchase a spare set of those headlamp surrounds if anyone has some.
quick edit: the guy I bought the headlamp grilles from also gave me some screws. Four are a bit long and two are shallow. I am wondering if the ones that hold them into place are really that long by chance and if they are, what side is the long and short. Looking at the picture, I would assume they have to be shallow based on the spacing of everything. Arg, almost need to see a spare set of these torn a part or just buy a whole assembly.
Old 13-01-2010, 03:22
Draconis's Avatar
If anyone has any spare time or is willing, if someone can take a picture of a headlamp setup after the grilles and the black surrounds are unbolted, that would be great. Just one would be fine. I want to see how much different the headlamp unit is to mine or if it's just the black surround that I'm looking at obtaining. Thanks.
Old 13-01-2010, 09:18
Draconis's Avatar
I figured since I had free time, I would take a part my spare headlamp unit so you can see and it would be easier for you to tell me what is different.
Here is the headlamp unit without the plastic covers on the sides the metal cover on the top. This would be the RH headlamp unit.
Note the key difference is that you have a black metal piece that the grilles bolt into. For us, we lack that but have a silver metal surrounding holding the headlamp into place.
This is the metal surround by itself.
Then what it looks like for the headlamp unit without the metal surround holding the headlamp itself in place. With the metal piece off, you can easily pull the headlamp out and it is left with the metal housing.
Thank you for the help.
Edit: Hey Umpkin, willing to sell/trade your headlight setup? I'll send you the metal pieces I have in addition.
Old 13-01-2010, 11:18
chewingtobaco's Avatar
chewingtobaco chewingtobaco is offline
chewingtobaco is an unknown quantity at this point
sup, my lights are set up the same as yours drac, i'm making some grills but i'm returning back to the pop rivets on the main housing and replacing them with nuts n bolts the grilles welded to the nut then bolting them up. you can see the rivets on the first pic of your right side...got 1 nearly done...looks good.
hope the pics help.
Old 13-01-2010, 18:07
Draconis's Avatar
I may have to look into that if I cannot find the stock replacements. Not too bad.
Old 14-01-2010, 09:31
should look cool, will try to get 1 finnished so you can get a better look bud.
will get some pics with it out too.
