Old 21-07-2011, 19:13
Yeh it would but rough. Is there any codes on the ECU?
Old 21-07-2011, 20:43
ollymk4escort ollymk4escort is offline
ollymk4escort is an unknown quantity at this point
ok cool well i pulled the plug off afm and it stalled.
wound in the screw on the afm a bit no real change.
I have not pulled codes yet was going to look tomorrow i think.
not sure whether it will give me codes properly as the loom has been cut and shut. ill try anyway.
I have pulled a plug and its very black/sooty and i have connected a pressure guage to the fuel and it shows just over 2 bar so thats ok.
Would a water temp sensor cause this also and does it have a cold start injector??
Old 27-07-2011, 18:54
Temp sensor is a common-ish fault of DET rich running, and can be tested with the info in the WSM,
It has a cold start valve located under the throttle body.
