Old 04-11-2005, 19:20
On a rally car the turbo don't go in reverse. They have antilag which keeps the turbo spinning at full speed. Thats why they last 10 miles. They glow white as they're on full spin for so long.
Anti lag is done by seriously retarding the timing and injector a load of fuel so that it burns inside the turbo...
Old 04-11-2005, 19:37
E11's Avatar
E11 E11 is offline
E11 is on a distinguished road
yea i was going to say that rally cars turbo's don't go in reversen that would completely defeat the object of anti lag
yeh als alters the ecu settings to fire fuel down the hot manafold on the exhaust stroke ( hot fuel hitting hot manafold ,igniting , spiining turbo faster on decelleration, ready for acceleration , fast skittle sound > turbo simple
dear o dear im drubnk!?
Old 05-11-2005, 13:40
stella?
Old 05-11-2005, 14:37
E11's Avatar
E11 E11 is offline
wish i could remember!
Old 14-11-2006, 00:21
Excite Excite is offline
Excite is an unknown quantity at this point
the chattering sound is the metal flap on the turbo right.....when the air is coming out. im sure thats right.
thats what we were told when a mates cossie was set up.
he he....every ones knows different
IM OFF LINE FOR A WHILE SORTING OUT NEW CAR/HOUSE/JOB
IM BUSY AS F**K
Old 14-11-2006, 10:01
No its the air stalling the compressor blades. As basically the compressed charge reverses back out of the turbo.
It causes stress on the shaft as a result. I personally wouldnt bother with a dump valve under 20psi. There arent many on the market which do a good job anyway, most are designed to be loud.
Old 14-11-2006, 13:02
But the the dump valve also helps to prevent stress on the shaft i always thought
Old 14-11-2006, 13:41
Yeah but its not an issue unless you are running high boost like 20psi plus.
Old 04-02-2007, 22:42
ONION ONION is offline
ONION is on a distinguished road
this debate was had some time ago but i cant remember the company that tested it.
they took 2 cars, same setup, one with dv, one without.
and over a set period of time tested the turbos for wear etc.
both wore equally.
as martin says, was around 18-20psi plus that it became an issue due to the higher pressure.
but then this would then depend on the unit you are using as most uprated units can take more abuse than a factory standard unit anyway.
my old red one used to chatter well.
all i did was fit a k+n filter and upped the boost a bit.
