Old 31-10-2005, 09:11
s12Rob's Avatar
s12Rob s12Rob is offline
Default turbo chatter
how do i get my silvia to chatter, i love the chatter sound
Old 31-10-2005, 09:15
I can only tell you the way mine used to chatter although it wasnt that loud.
Are you using a dump valve at present?
Old 31-10-2005, 09:37
s12Rob's Avatar
nope im not
Old 31-10-2005, 10:06
You need an aftermarket air filter, as a standard one will suppress the noise.
Turbo chatter is when the volume of compressed air forces its way back through the turbo (the wrong way). The turbo slows down loads when this happens and the noise is the chopping of the air coming back out.
On the standard pipe from turbo to throttle body there is very little volume there so the sound is hardly audible as there isnt much air to go back through the turbo. If you intercool it you are multiplying the volume and then you'll get a good chatter. The larger the turbo the better the longer the chatter lasts. This actually causes harm to the turbo by stressing the shaft as it slows down and may even almost go backwards. The reason why a dumpvalve is used is to reduce the back pressure on the turbo and therefore reducing the stress on it. Ideally you want a dump valve that only goes off on full boost, so an adjustable on is ideal, as I personally don't like the essex sound of a dump valve.
Old 31-10-2005, 17:39
Take it from that mate
Old 03-11-2005, 21:55
E11's Avatar
E11 E11 is offline
E11 is on a distinguished road
same as rally cars chatter.......
but they make a kind of skittle ing sound , usually un decelleration into the corners when they are shifting through the gears
Old 04-11-2005, 00:21
Thats the sound of anti-lag...
Old 04-11-2005, 13:59
E11's Avatar
E11 E11 is offline
yeh ASL thought so...
Old 04-11-2005, 17:09
the chatter will be louder if you if an IC
Old 04-11-2005, 18:47
Default chatter
yea the chattering sound is the sound of the turbo goin into reverse but they can afford to rebuild it after every couple of rallies to repair the damage
