Old 23-02-2008, 19:56
Oscar's Avatar
Oscar Oscar is offline
hey if u fancy it im in town wi niki, lil moo, and dan dan
Old 23-02-2008, 20:03
cheers fella, nice of ya to ask , but i'am gonna be good and cook our lass and kids a curry.have a goodun .
Old 24-02-2008, 01:42
Oscar's Avatar
thats alright mate, we'll have 2 go 4 a beer sometime, was a goodnite
Old 24-02-2008, 13:16
Oscar's Avatar
ok other afm same problem, primera afm, did not start lol
Old 24-02-2008, 23:44
Check everything in my previous list
Old 25-02-2008, 04:05
odd. To be honest it should have worked OK ish with only a real difference at higher RPM.
Could well be a problem with the wiring to the AFM, or maybe the TPS
Old 25-02-2008, 10:46
TPS will only make a difference at idle, if the switch is open it advances the timing and the revs raise. If the switch is permanently closed (the 2 wires shorted together maybe) it may confuse the ECU as it will think the thottle is shut even if it isn't.
Do an ECU code check, you stamp on the throttle to tell the ECU the switch is working so then it won't bring up the code, but of course it will tell you if it sees no change. An ECU check might bring up other stuff too.
Old 25-02-2008, 11:32
Oscar's Avatar
well it nearly cuts when its cold, but had a fiddle this morning, and when i wiggled num 1 injector it stutted! Maybe found it
Old 27-02-2008, 14:13
Oscar's Avatar
Wink
injector had a crapped conection, sorted! Tho now it idles at 1200rpm lol! Im sure this engine hates me hehe
