Old 23-02-2008, 15:23
Oscar's Avatar
Oscar Oscar is offline
Default missfire
last nite driving home from work, got a bad missfire, between 2500k and 3k, checked plugs leads and vacum lines, and when i slowed down my power steering went heavey a few times... Im confused....
Old 23-02-2008, 16:01
Oscar's Avatar
any sugestions? Coilpack? Would an s15/s14/s13 coilpack fit?
Old 23-02-2008, 16:02
I would check all the following starting with a compression test
air flow meter
air flow meter plug
spark plugs
Head gasket blown
Ht leads inc king
coil earth
rotor arm
dizzy cap
boost/vacuum hoses
Good luck
Old 23-02-2008, 16:04
It doesnt have coilpacks.No they wont fit
Old 23-02-2008, 16:06
Oscar's Avatar
cheers! Well i checked the plugs, leads, vacum, maf was cleaned last week, i hope its not the hg, it dosnt over heat, no coolant loss... And its fine apart 4 that 500rpm gap
Old 23-02-2008, 16:08
Oscar's Avatar
no coil pack? What an amateur! Lol, well looks like my sr build will have 2 speed up
Old 23-02-2008, 17:08
it has an individual coil obviously, Just not 1 'coilpack' per cylinder like the s13 det engine has
The coil is underneath the air flow meter but tbh i think a compression test is the first thing to do,if that is ok followed by a new set of plugs
seems coincidental that you cleaned the afm last week. Why did you do that and how.
Old 23-02-2008, 17:50
zxocmars zxocmars is offline
Leads that are on it are practically brand new, from Nissan, Plugs too.
Could be the AFM
Old 23-02-2008, 17:59
Oscar's Avatar
cleaned the afm idle was a bit funny, cleaned it using a kit i bought in germany a couple of years ago, a spray and very tiny soft brush, cost me over a hundred euro from merc, had a amg c43, wish i had known then and just used wd40
Old 23-02-2008, 18:01
you don't want wd40 carb or brake cleaner would be best.
