Old 19-08-2006, 20:55
FLEXXX's Avatar
FLEXXX FLEXXX is offline
Default blown turbo
i think i might have blown the turbo today as my s12 is not taxed or tested i just pull it out from the garage and start it and admire the car and plan a few bits on what i want to do and imagine the finish article well on this event i realised some smoke from the zorst (clear) so i let the the car warm up an decided to tap the gas then smoke galore (white) does it mean the turbo is gone im not worried as a turbo was always on my shopping list it just means that the s12 has been delayed of its release date back to the cell till the next parole date any advice on turbos and what to pay as ive never had to deal with blown turbos before until now
Old 19-08-2006, 22:56
Could it not just be condensation and from sitting for a while not being used much?
Old 20-08-2006, 00:20
FLEXXX's Avatar
well that was my initial thought will have to see what i make of it in the morning fingers crossed
Old 20-08-2006, 08:56
Back Seat Chatter!
doesn't white smoke mean you're running rich?
Old 20-08-2006, 11:22
Jeff Jeff is offline
Jeff is an unknown quantity at this point
White = water = more likey head gasket that turbo I'd have thought
Or, being more optimistic, may just have been a lot of condensation from sitting for a while as Pukka said. Check for mayo in the rad cap and maybe do a compression test.
Old 20-08-2006, 18:00
ianv72's Avatar
ianv72 ianv72 is offline
ianv72 is an unknown quantity at this point
sorry to hear that flexxx , hope everything goes well
Old 20-08-2006, 22:12
FLEXXX's Avatar
no mayo around the oil cap as that was the first thing i checked before buying the car i think it might be as pukka said condensation will let you know as soon as its a hectic month
Old 20-08-2006, 22:26
Have you done anything to the engine since you have bought the car?
Old 21-08-2006, 19:45
FLEXXX's Avatar
no nothing its been parked up since ive got it all i do is start it up every other day just warm it up as im just waitng for some cash so i can order the springs so i can fit the new kyb shocks and grooved discs at the same time will start the car up later this evening and report back on the level of smoke i did realise a small hole from the rear of the exhaust smaller than a 5p piece
Old 22-08-2006, 13:43
FLEXXX's Avatar
ok ive just took off the pipe between the throttle body and turbo on the turbo end there was a small oil puddle in the orange rubber neck is this normal or not as for tghe white smoke it is still there i will get some more fuel and some redex and see what happens as it has been parked up for 6yrs or so apart from that all is well it starts first time the interior is mintas is the body everything is in good order apart from this but youd expect a few bits
