Old 02-10-2006, 10:47
Draconis's Avatar
Draconis Draconis is offline
Default Weight distribution and ratios
Post your S12's weight. Front. Rear. Whole.
After you do that, post up what is with you S12: mods or weight reduction.
Gas liquid weight: approx 8.18lbs per gallon.
You can do this by going to a weigh station after hours. No one goes there but the scales are usually left on. At least up here in Wa.
Draconis: 1988 S12 VG30E Automatic
- Stock car. Spare tire in rear, stock rims with rubber (15in), full tank of gas
Front: 1655 lbs
Rear: 1450 lbs
Total: 3105 lbs
53.3% weight in front, 46.7% weight in rear
Draconis: 1987 S12 RB20DET
- full size spare in rear, battery rear passenger corner above gas tank, RB20DET swap, FMIC, Imprezza seats, SSR GP-Omega rims (17in), low profile wheels, full tank of gas
Front: 1600 lbs
Rear: 1430 lbs
Total: 3030 lbs
52.81% weight in front, 47.19% weight in rear
*These weights are subject to 5lbs possible difference above or below. But to help eliminate that variable, both Randy and I jumped on the scale separately without cars to see how accurate it was, and they were accurate to our personal weights. We will be doing these weights one more time with the RBS12 later this week to make sure of the numbers.
Old 02-10-2006, 13:27
individual corner weight figures are far more usefull. And until i have coilovers on mine one day i dont have any need to do it.
Old 02-10-2006, 20:34
What is the stock s12 w/ CA18ET mk1 and mk2 specs?
Old 02-10-2006, 21:04
mk1 is 1135kg, auto is 1155, mk2 is 1195, auto is 1215kg, and the mk1 fj n/a is1170kg.
